InstallShield Error -6002: Unable to run setup.exe files
Hello experts,
Please consider reading my problem and help me solve it.
I’ve a problem with my Install shield. When I run any form of setup.exe file, it is showing this following error:
Setup has experienced an error.
Please do the following
• Close any running programs
• Empty your temporary folder
• Check your Internet connection (Internet-based Setups)
Then try to the Setup again.
Error code: -6002
Only recently I purchased Photoshop CS, and I’m getting this very same error when I click the setup.exe file. I could not complain this to Adobe, as I’ve this problem with all my files that I run in Install shield.
I’ll be much thankful for each and every response from your side. Thanking you again.
