stevecanry
1660 points
Posted on - 07/18/2011
Posting here an error scenario that I know would also be interesting to read upon, an error occurred while I was using snagit application, the error message appeared while I am in the middle of my work using snagit
he instruction at “0x01c2596c” referenced memory at “0x01c2596c”. The memory could not be “written” .
Click on OK to terminate the program.
Click on CANCEL to debug the program.
OK Cancel
The error in the instruction at “0x01c2596c” referenced memory at “0x01c2596c” is so familiar to me with other software, what I did before I just remove and re install the software, but now it seems to be different, its no longer a solution as before,
Please help me figure out some solution on this issue,
Thanks for reading.
jere366
The instruction at 0x01c2596c referenced memory at 0x01c2596c
I've also had the same error when running a program of which was a game in this case. The main problem is usually an error in the application it might have some of its files corrupt or missing. The software could also be having problems with some of its memory since they need to be 'written' as the name suggests.
The probable solution for this is to look for a software known as 'hijack this' mostly in Google to find the original site. After installing, run it on the software by writing the name of the software to look for errors. It may fix the error most probably.
You may also try looking for another software like that and install to see whether it will have the same error.
Hope it helps.
Back when I was still using Windows XP, I sometimes see that error right before I shut down the computer or when restarting the system. The error normally goes away the next time the system starts. So, in your case, when you see that error when using an application, close the program then restart the machine. See if this fixes the problem.
If this doesn’t work, try to uninstall and reinstall the affected program. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select the affected program among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install the program back or update to the latest version. See if this works. If the problem continues, test the memory modules. For x86 or 32-bit computers, download MemTest86. For x64 or 64-bit computers, download MemTest64.
