murz furby 10 points N/APosted on - 06/27/2013
Hi All,
I have downloaded Yamb in my Windows 7, I am not familiar with Yamb, So please do the needful for giving instruction on using Yamb to easily edit, combine and cut audio files.
Yamb is a nice tool for working with audio and video files. It supports wide variety of file formats including mp3, mp4, 3gp files.
While its a full featured tool, it lacks necessary documentation, however, there is one very helpful video tutorial available in Youtube which demonstrate how to use Yamb to manipulate audio files.
Please see this video "How to use Yamb to easily edit/combine/cut audio files | video tutorial by TechyV", I am sure you would find it to be useful.
If you have further questions, please feel free to ask.
Yamb is an acronym and it actually means Yet Another Mp4Box UI. It is actually a new graphical user interface for the MP4box that uses a command-line tool. The graphical user interface is mainly designed for Microsoft Windows operating system and may not work on other platforms. You can use it to join, split, and create 3GP or MP4 files that contains 263, h264, m4v, 264, cmp, h263 video streams.
Or it may also be from vob, avi, ogg, mpg, mp4, qcp, mpeg, 3gp, as well as mov files. The audio streams may be captured from mp3, aac, awb, ac3, vorbis, amr, msv, and evc as the input format. Here’s an example on how to use Yamb to combine recording fragments. Open Yamb, select Editing, and then double-click “Click to join supported files”. See the image below.
In the “Concatenation of Files” window, click Add to select and add files. After adding files, click Browse at the bottom to select your target folder for the output file. See the image below.
Once all files are added and the target folder has been selected, you may now click Next to begin the processing. See the image below.
Just wait for the process to finish and then check the output file. See image below.
If you wish to download Yamb, visit Yamb Website Downloads. Watch also “How to use Yamb to easily edit/combine/cut audio files | video tutorial by TechyV”.
Lead generation and demand generation are two of the business strategies that help businesses grow. It creates a pipeline of interested customers looking to find out more. Lead generation on the contrary, is able...
1....
