What are the steps to follow to acquire a Google Wallet? I am a twenty years of age and a freelancer. I would be extremely happy if I am able to acquire a Google Wallet by following the simplest detailed instructional steps. Does the acquisition of this wallet demands some payment? And if so, how much with respect to minimum amount. Thank you.
Instructional measures to consider in acquisition of Google Wallet
Hi Samuel. Google Wallet is indeed the future of settling your bills through electronic means. Your smartphone can now be use not only to send messages, initiate calls, surf the net but now act like a credit card.  You can just integrate your debit or credit card with the Google wallet but if you don’t have it, just use a prepaid card and refill it. Here are the step-by-step process in acquiring your Google wallet. First set up your account with Google. If you already have a Google account, then just go to wallet.google.com click now Sign in and then set up your Google wallet. Enter your information like your name, address, birthday, etc and click Accept and Create. Now on the Settings page just verify your identity. Then later create your PIN number just like in creating your bank ATM. Next, install the app from the homepage, select whether your’re using an Android or iOS. Once it is already installed. Log in with your Google account. Next step is to add money to your virtual wallet. So later you can buy online or shop in offline stores. Now, here is the most important part, adding money. Now from the upper left corner select Wallet balance and then tap Add money. Choose the method how you will add it and then tap Add money. Lastly, activate your wallet by selecting Wallet Card & App and once you’re identity is verified, you can request a card which will be mailed to your residence. That’s it simple and practical.Â
