Hi Experts,
I have bought a software Keylogger recently to use on my desktop.But Avast detected it as malware the moment it was installed.If anyone can guide me on Keylogger avoid Avast it would be a great help.Thanks.
Sharlene Ruby
Instructions on keylogger avoid avast?
Hi there friend,Â
I also own Avast and this happens to me more then often, since it locates viruses where they simply don't exist.
So I searched the net and found a solution to this problem, and a quite easy one indeed. Â
Go to Avast, the icon next to your computer time and find "Exceptions". Once there just puts the program out of the Exceptions, so Avast does not turn it off next time you start it. Avast can also ask you at the start do you want to put the program to Exception, so just avoid that.
Regards,Â
*Forgot to mention, the Exceptions or Exclusions chest is in the Settings panel 🙂
