Is there anyone who could provide instructions on setting up a Prep Exchange 2003? Whenever I try to set this up myself, a message prompts that says, “Setup encounter an error while trying to contact the windows active directory and fail to connect to schema master for this active directory forest. ”
jaymark
5 points
Instructions on setting up Prep Exchange 2003
Greetings..
I have some suggestion and looking forward to answer your question and i hope it will work for you. Regarding your problem pop up of "Setup encounter an error while trying to contact the windows active directory and fail to connect you must consider the following:
The server must be the domain of exchange server the reason is to operate within and you must also to ensure that your operating system up to date and all are updates like patches that the reason also why you are encountering a problem.
You can check this link for guide and other instruction to help you most credited to cregan. wordpress. Here is the link.
I hope it will answer all your problem and will help you.
