jeremy ngo
20 points
Posted on - 04/13/2012
I have a lot of disk space (about 1 Terabyte) but I'm experiencing errors in OLAP that is a bit annoying. It says that I have insufficient disk space whereas I have a lot. What can I do to fix this error? Does the location for temporary files have limited space?
Insufficient Disk Space for Temporary Files
During running a program there creates temporary files automatically. It covers your disk space and may create some other problems. So better you should delete them frequently. It should make your computer fast and you will be able to use it smoothly. Command %temp% from the Run to delete temporary files from your computer.
All the temporary files may not be deleted at a times. Try to delete them separately. Virus may also be responsible for your current problem. If the information resources of the hard disk are corrupted by Virus it may shows in this way. Scan your computer with an updated version of Antivirus.
Your current problem will be solved.
I hope you understand it.
Thanks  Â
