Hi! I recently downloaded BlazeDVD, and I noticed that in the system requirements, one must have a VGA card that supports DirectDraw. The problem is I don’t have one. What are the possible consequences of not having the said system requirement for a blaze dvd player 5 pro? Thanks in advance.
Insufficient system requirement for blaze dvd player 5 pro
The version of Blaze DVD that you are currently using is outdated and I suggest that you get the most current stable version from their website, either the free version of it or the pro one. The most current stable version is v6.1.1.
For version 6 is not a must you have DirectDraw. Here are the minimum system requirements:
1.   CPU : 1GHz Intel/AMD processor or above
2.   System Memory : 256MB RAM (512MB or above recommended)
3.   Operation System : Windows XP, Windows Vista, Windows 7, Windows 8
