Integrate Email System using Google Calendar with Luminis 4.3
We are currently in the process of transferring our e-mail system to Google. We consulted a number of experts regarding this matter and they advised us that it is impossible for us to integrate the systems using Google Calendar with Luminis 4.3. I guess if it this doesn’t work then we could use our Sun Java Calendar (from Suite 5). If you have knowledge about providing Calendars to persons using Google apps then please help us regarding this matter. Thanks a bunch to those who can help.
Answered By 0 points N/A #114526
My suggestion here is that you should not use the SunGard’s provisioning part for that process, but instead you should just purchase the single-sign on part.  The reason why I am suggesting that is because the adapter does not yet support role-based placement into Google OUs.
For your case you will need to have attributes that will offer control to the features that are available to either ou, for example when it comes to maintaining a searchable directory. You will also need to use the  Google Apps Directory Sync tool to do the provisioning of the system.
Hope this helps.
-Richard Gabriel
