Integrate Multiple videos to moodle
Hi
How do i integrate video into moodle, how can i upload multiple videos into the moodle? How do i share a video?
Thanks
Hi
Thanks
In order for you to upload multiple videos at once in Moodle is to follow these steps. First, you need to zip the files that you wanted to upload. To do this, select all the files you want to zip, right-click with your mouse, select ‘Send to’, and click ‘Compressed (zipped) folder’. You will notice that a new zipped folder will appear right there where your files are located and named after the first file. You may rename it if you like. Second, go to your courses homepage. Click on the ‘Files’ under the Administration block. You can now upload the file by clicking the ‘Upload File’ button. Wait until you see a ‘Browse’ button, click on it. Select the zipped folder you have created a while ago and click ‘Open’. Next, click on the ‘Upload this File’ button. To unzip, click on the Unzip link next to the zipped file. Click OK. Hope this will help you. Thank you.
Notifications
