Integrate SUSE Linux on windows machines
Hello friends
I am running a windows machine and would like to add SUSE Linux. how do i integrate SUSE Linux on windows machine?
Thanks
Hello friends
Thanks
I’m not familiar with creating a multiple operating system with Windows and Linux. Try visiting some web sites about Linux and learn on how to properly configure it to boot together with Windows as dual-boot system.
In Windows, creating a system that boots on different operating platform is not that hard. You just need to properly partition the hard drive so you can allocate which operating system will use drives C, D, and so on.
In creating a multi-platform system, you need to have a Windows NT-based operating system to be installed on drive C because Windows NT-based platforms are capable of booting in multiple operating systems.
Then after you have installed let’s say Windows XP on drive C, you can now install the next operating system on drive D. You just need a bigger hard drive to fit the operating systems you are going to install.
