A K Azad
35 points
Posted on - 09/30/2016
There arises a situation where the integrated camera of your laptop just stops and you have no clue because you were video chatting with your friend the day before. You might have checked the camera status or the wiring but the problem still exists. The reason may be an outdated version. How to update integrated camera software for Windows 7?
Integrated Camera Software For Windows 7 Updating.
UPDATION:
1. Windows Update WINDOWS UPDATE.
Open device manager.
Search for integrated camera. Right-click on it and select Update Driver Software.
Click on Search automatically for updated driver software.
Wait till a message prompts informing you about the driver installation.
LENOVO SUPPORT
Find your operating system and laptop model number.
Go to Lenovo support page.
Click the icon having three bars.
Click the drivers and software options.
2) Type in your laptop’s model or the name of your laptop.
Let the detection take place.
From the download section, search the drive you want to download.
3) Click on the download link. This will download the driver.
4) Follow the onscreen instructions to install the driver.
DRIVER EASY
Click on scan.
5) click on update.
Camera driver is updated.
