anonymous
7060 points
Posted on - 11/10/2011
How do you integrate Active Directory to Spice Works? When filling out the user info and saving, it says "Unknown Results (8) " I am on Windows Server '08 R2 and I have primary domain controllers with backup. I need help in setting up Spice Works in my domain. Only one computer is listed, even when I have imported all users. Also is there a script or application that can work from one OU to another? I have a spreadsheet and I can convert devices to CSV if that helps.
Jackman
Integrating active directories to spice works
Spice works is a free Active Directory's Management tool that helps in view each user's profile. To inter grate it you have to disable all user's accounts and reset their password, next you will be linking devices to specific users. Go through all tickets opened by specific users in a quick view. The next step is for you to access every user Active Directory information. Spice work is free to download, install and use people view to manage your Active Directory Account.
If you are interested in downloading then visit Download Link then download it for free from the two downloading windows present on this page.
