Nick Smith
Posted on - 10/21/2011
I'm an office assistant and I send out a lot of emails to all the other employees in the office. Most of the time I send out official communications what are on an Excel file; then customize it and send it to everyone. It's very troublesome editing each template then sending it especially if there's a considerable number of people in the company.
Is it possible to have a macro created so that I can just push a button, then everything will be filled in and the email will automatically be sent through Outlook?
Anisu
Integrating MS Excel and MS Outlook
Well, there is not an automated system for sending an e-mail to anybody else in the outlook. There is a possibility that you could save your e-mails before you have to send them to another employees at your office.You can send the same e-mail to the 5 persons at the same time or you can customize your e-mail while you are ready to send them.
If you don't think it as bothersome. You have to send e-mails one after another to all the persons. The method you need can be selected. You can send e-mails chronologically to free you troublesome.
lee hung
75 points
Before you start text the program, you must smuggle or transfer the records by using the option in the access file menu and access the e-mail such as writing, then simply refer to the mail receiver.
After that, use the OfficeLinks article to send the items to other programs and then use the basic Windows. Copy paste the skills and then link the statistics between programs. Combine the data from the access desks to the Microsoft Excel and tags and other reports using the Word Mail.
