Intel C++ Compiler Professional Edition 11.1.051 refuses to install
Hi
At present we are upgrading our devices to Intel C++ Compiler Professional Edition 11.1.051. For the majority of the developers the set up was a breeze.
Two developers have a problem where they cannot install to the manual "C: Program Files/Intel" folder however. The installer shows that it is a worthless directory. This happens after the installer takes out every file into the download folder.
I should mention that, all antivirus programs are turned off. Normal File sharing is also off. The system has also been rebooted. All the other applications install normally to the Program Files folder and the installer has Admin rights.
I noticed one other incidence of this weird behavior on the Fortran forum with 11.1 but no solution was listed there.
We need a solution.
Please help.
Thanks in advance.
Error:
Invalid directory: C:Program Files.
Access is denied
