Intel core 2 duo or dual core better
Want to buy desktop for business with Intel processor. Which one should I buy – Core2 duo or Intel dual core? Which is better? Why?
Dear,
Intel dual core is one of the advanced technologies that Intel introduced. The updated version of Intel dual core is Intel core 2 duo. Both have high processing speed. With better ram both can solve problems very fast. The complete package of computer consists with processor, ram and hard disc. If you get a good combination then you can work better.
Thank You.
Greetings,
In my opinion base on my experience and research, what will be the best choice computer for your office between Intel Dual Core and Intel Core 2 duo I would suggest to you if you are aiming for a great Computer performance then you should choose Intel Core 2 duo (Intel® Core™2 Duo Processor E8400 ) over intel Dual Core E6600 simply because Core 2 duo much powerful and has more advance features than Dual Core and. Although they have similarities in having 2 cores and 2 Threads their specification is not the same.
Here are their Specifications so you can easily understand.
i hope this answer will help you to ease your doubts in comparing those 2 intel products. have a nice day!
First of all they’re basically just the same, they have 2 cores. Secondly, the core actually just means CPU. Thus, both of them have 2 CPU but they are just integrated. The difference is that dual core is generic while Intel core 2 duo is a brand name from Intel of their products which has dual core. They only vary basically in speed a little. Hope this helps.
In my opinion core 2 duo is better as it is revised version of Intel dual core .Also it is fast compared to dual core and computer performance is fantastic.
