Intel core optimizer got installed accidently, How to remove it ?
How to remove intel core optimizer? It got installed accidently along with a free game and now blue screen crashes appears frequently. How to remove it ?
You want to remove Intel core optimizer. It's very easy to remove it not a big deal. Follow these steps it will uninstall it and the problem will get solved
1. Click on the start button and then go into the control panel.
2. A window will open. Just find their program and features.
3. Click on program and features. It will open a window.
4. Now search the Intel core optimizer and select it.
5. When you select it at the top you will receive an option to uninstall or double click on it.
It will remove Intel core optimizer from your computer. Hope it will solve your problem.
If the program came along or bundled with a free game you installed, try uninstalling it with Revo. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select Intel Core Optimizer among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later.
When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds. This removes everything the program created on your computer. When it is finished, exit Revo then restart the computer. If this doesn’t work or the blue screen error keeps appearing, try removing the program in Safe Mode. Restart the computer then press F8 before the Windows logo appears.
In “Advanced Boot Options” screen, scroll down and select “Safe Mode” then hit Enter to boot. Once in Safe Mode, uninstall the program in the Control Panel.
Notifications
