Zachary
200 points
Posted on - 03/16/2012
 Hi experts I check the consents of the particular file and whether the network tool is mapped as well as obtainable. I have corrected the file and tool which was being contacted. I have changed the protection, exact file, or procedure used before restarting the program.
Severe (9): Permission to access file denied FOR$IOS_PERACCFIL.
Need a solution to solve this error. Thanks in advance.
Intel Fortran run-time error help
Hey Dear!
Do not worry about this problem. I had also faced this problem but I succeeded to overcome this error. I search on the internet for this problem and then I got a solution. I applied that solution on this error and I was succeeded to overcome this problem.
First of all you have to make sure the protection of specified file also ensure the availability of Network device, which should be mapped. Before you run the program, you have to change the specific file, protection and all used processes.
After doing all this, you will not face this error anymore. Hope it will help you.
Thanks
