Hello Everyone,
I am using 2nd Generation Intel Core Processor in my office, recently my Graphics card seems to be having problem with the driver. So I am in need of Intel HD Graphics driver for Windows 7 64bit, Please help me to find it online, in order to solve my Graphics driver related issue.
Thanks,
Zachary Cashh
    Assuming that your PC doesn’t have discrete graphics card, I would like you to go to the official intel HD graphics download page, and select the desired options and install the drivers.
You haven’t been specific about the problem. If there is still problem, then clean the temporary files and uninstall the graphics drivers once.  Install the drivers from the motherboard’s CD/DVD.
Many times display problems emerge because of non-proper shutdown of the PC. You can try by replacing RAM into another slot and check if things work. Faulty RAM can also be the cause of the display errors.
Thank you for writing to us but if you don't specify your motherboard id along with your Intel HD display card number there is no relevant way we could figure out the driver for your HD graphic card.
Well you can check Intel's website for more information on your driver. Or check this link for more information.
Welch Sanger
