I want to buy a new computer; I will use it to play games. I want to know which the best configuration for a PC gamer is. Which configuration should I have? Intel and Nvidia or AMD and ATI. Which is the best processor? Which is the best video card?
Intel or AMD/ATI ou nVidia
Hi there Boris simone. Not only you I also like to play games and that’s always require a high configuration pc as any 3d game need rendering and rendering needs more processing speed as well as ram and video card. If you need high configuration in low price I recommended you to buy AMD processer. Till today the best processer is Intel 2nd generation corei 7 extreme processer with 6 core and logical 12 core at speed more then 3 GHz. But you can also get AMD processer with 6 core but you can buy AMD processer with 4 cores that’s enough but you need to buy as latest video card as you can with high memory. You can buy “MSI GeForce GTS 450 Cyclone”.
MachanLK
I am using AMD for last 2 years without any problems with good speed. So if you need good speed please go for AMD
