zenith keen
30 points
Posted on - 08/20/2012
Recently I installed Intel PCI communication controller driver and in the middle of installation I faced power failure.
Since then, I’m receiving error on PCI communication controller.
Does anyone knows how to get rid of previous installation, so I may reinstall drivers completely again?
Intel PCI communication controller driver not installed successfully?
Hello Zenith,
Use the following steps to resolve that issue:
Go to the device manager, and then click on the pci simple communications controller.
After that go to property and then go to details.
You should see a code like this: PCI/VEN_8086&DEV_27D8&SUBSYS…
What the VEN code stands for is the vendor while the DEV code stands for the device.
After you have successfully acquired the two codes, you will need to go to www.pcidatabse.com.
You will need to enter the two codes and after which you will get the name of your hardware.
After that you can search for a driver download for your hardware.
Carl
Restart your computer. Few seconds after restart, press “F8” on your keyboard fast several times, until you get a screen with Windows recovery options. Chose “Safe mode”, press Enter on your keyboard, and wait until Windows loads.
Go to START, press right mouse click on Computer (or My Computer), go to last option (“Properties), then to “Hardware” tab (in Windows Vista/7 skip this), and choose “Device Manager”.
Under modems, find “PCI communication controller”. Click mouse right button on it, then choose “Uninstall”, and press “OK”. Restart your computer regularly and install that driver again.
Just uninstall the driver from the device manager then download the driver again from the manufacturer’s website. If the driver you are installing is the chipset driver, you can’t uninstall it so just download and install the driver again. If your computer is from one of these computer manufacturers, download the complete set of drivers from here:
On the support page, enter your computer’s serial number or model number then click to search. When your product is located, click your product to go to the download page. Select your correct operating system before downloading. If a different operating system is displayed or detected, click to change then select your correct operating system. Download and install all available drivers and software for your computer.
