Interchangeable lens cameras in market
I want to buy a camera which can use an interchangeable lens that means where I can change lenses frequently. Are there any cameras which I can buy please list the available cameras.
There are many cameras which are capable of interchangeable lenses. But here is a list which is considered to be the best and most of all top rated.
Thank you.
I think, the below options can make you comfortable. Those cameras are available in https://www.amazon.com/
Sony Alpha NEX-7 (with 18-55mm lens)
The price of this camera is $1149.99 to $1,349.99. It releases on January 3, 2012. It has 24.3 mega pixels resolution with 82.5mm F/3.5 Lens27. The Lens System are 3 x x Zoom lens – 18 mm – 55 mm – F/3.5-5.6, optical sensor size15.6 x 23.5mm and optical sensor type Exmor APS HD CMOS. It also supports Image stabilizer Optical (Steady Shot)
Panasonic Lumix DMC-GH2 (with 14-42mm lens)
The price of this camera is $699.00 to $920.77. It releases on December 15, 2012. It has 16.05 mega pixels resolution with 84mm F/3.5 Lens28. The Lens System are 3 x x Zoom lens – 14 mm – 42 mm – F/3.5-5.6 Micro Four Thirds, optical sensor size13.0 x 17.3mm and optical sensor type Live MOS. It also supports Image stabilizer Optical (MEGA O.I.S).
Olympus OM-D E-M5 (with 12-50mm lens, Black)
The price of this camera is $1,149.00 to $1,299.99. It has 16.1 mega pixels resolution. The Lens System are 4x x Zoom lens – 12 mm – 50mm – F/3.5-6.3 Micro Four Thirds, optical sensor size 4/3’’ and optical sensor type Live MOS. It also supports Image stabilizer Optical (image sensor shift mechanism). Here to buy.
