Interconnecting MS Access Database with VB 10
20 points
Posted on - 04/06/2015
Hello!
I purchased a new computer. This came in with bundles of MS Access from MS Office and MS VB 10. Can you tell me step by step how to connect MS Access Database to VB 10 or vice versa? Do I need to use a data connector to make this work? How can I locate the database using MS VB 10? Is there any other connector that I can use to connect database? How fast is the response time?
