athan haas
20 points
Posted on - 01/25/2013
Hi Experts,
I want to convert images in jpeg format to cdr format.
Is there any software which may help me to convert jpg to cdr.
If you find any website which converts these files online, please share the link.
Interested to covert jpg files to cdr files
Hello there Athan,
CDR, also known as Corel Corporation's DRAW's default format. For you to be able to convert these files to jpeg, jpg, png or any other graphical formats here are the steps :
1. Launch CorelDraw and select "Open" from "File" menu and then browse your hard drive for the location of the image that you need to convert.
2. Select "Save As" from the "File" menu and choose ".cdr" from the list of options available. You can also rename your file if you want and then click "Save" button to exit CorelDraw.
Hope this helps.
Waall Mike
