We currently have an intermittent Flare on a Windows 7 box. Please let me know if this is a Windows 7, Flare or a hardware problem. We could not figure out why it is happening and we think the solution is to reinstall Flare. Do you have any ideas?
lee hung
75 points
Intermittent Flare on Windows 7
Hello Alfie Swayze,
It could be a problem being caused by either of the three, it may be a problem being caused by the operating system, some hardware may be not functioning properly or the flare that you have installed has problems that are causing it not to work properly.
But I will suggest that you do a reinstallation of the flare and see how it will work. If that does not solve the problem then you will need to troubleshoot for hardware problems or problems with the operating system and fix then and see if the problem will be solved.
Hope this helps.
__
Regards
Lee Hung
