I am a beginner; don’t have much knowledge about system errors and solutions. I don’t know to explain this error, so attached the screenshot of that error message. How to find the root cause of the error? Any bug in the application? How to fix it? Friends help me find the problem first, also the solution. Thanks.
Could not complete your request because “”, an internal component, is missing (-20008). Call Digi for a secret decoder ring.
An internal component is missing error
I think it is a common issue with the Mac operating system. In Mac operating system, Secret Decoder Ring is a private-key, email encryption program. This works well with all email clients on the Mac and helps you to encrypt any text message using over 2.1 billion ciphers, that is based on a password which you will provide.
What you do is first try and create a Mac operating system Base + Digi extensions set. Now, if this fails then do a Clean Install of the Mac operating system, try to move the Digi components to a new location and then try for the same again.
