Internal Error 2503 – Vista Installation/Uninstallation Error Fix
I am facing a critical problem with the installation of MS Office and Adobe. In both of these installation processes, I was notified that “new updates available”.
There are several reasons why this error happens. I will enumerate several steps for you to follow. One of the methods can resolve the error.
First: Unregister your Windows Installer then register it again
1. Click the Start button then choose Run
2. A window will appear. Type msiexec/unregister then choose OK.
3. Repeat step 1.
4. A window will appear. Type msiexec/regserver then choose OK.
5. Try to install your program again.
Second:
1. Click start button then choose Run
2. A window will appear. Type dcomcnfg then choose OK
3. Click the Default Properties tab. You will see the Default Authentication Level (click Connect) and the Default Impersonation Level (click Identify) then choose OK
4. Repeat step 1
5. A window will appear. Type explorer/select, %windir%system32msisip.dll then choose OK
6. Change the name of the msisip.dll file to msisip.old
7. Try to install your program again
