Internal Error 52768. The installation failed
Hi there,
When I attempt to install Xerox on a Windows 7 (32-bit) workstation, I get the following error. The installer is downloaded from the official website and it should be good, without any error. Does anyone have any idea about this error? How can I solve this please? Thanks.
Xerox Setup Wizard
Internal Error 52768. The installation failed and will now roll back. Please check the log file for more error information.
Error: Create VirtualDirectories[Exception]:Unknown error(0x80005000)
OK
