An internal error has occurred stack overflow
When I am attempting to change the photo image or use the Adobe reset in develop module I stuck up with an error message. Then I click ok button in the window, the photo image is not reset. I tried with all different kinds of images but nothing happens. Is this a bug? Is there any problem with the installation? Help please. Thanks.
An internal error has occurred: ?:0: stack overfow
Answered By 590495 points N/A #189443
It is an internal error stack overflow which is really an error triggered from within the application and sometimes is affected by the things or data it processes. I usually get this error before when I am forcing a program to process something that is beyond the allowed capacity. In your case, since you are working on an image, make sure when you applied something on the project you wait until it is completely finished.
Sometimes when a task is not yet finished and you started again a new one without waiting for the previous job to complete then this error can appear. If you are working on Adobe, restart Adobe, load the project and restart whatever it is you are doing. If the same error happened, try reinstalling Adobe.
Also make sure when working with your project, don’t open any other programs to make sure no other processes are running besides the one you are using.
