An Internal error occurred ASSERT: Pointer is NULL… (emu-core. c/2563)
At this point are the pop-up error message I received during opening Garena Messenger and LoL client
![ASSERT: Pointer is NULL... (emu-core. c/2563)](https://www.techyv.com/sites/default/files/users/Roger%20Garrison/Internal-error.jpg)
Internal error…
Internal error…
Hello Dear,
First of all tell me yours windows, operating system and where you are installing the game?
Make sure that you are running a program as administrator account and you are installing the game on its default folder like this path “OS (c) > program files > lol”.
If you are using same path then you must do a clean reinstall to fix this issue. Don’t change the file directory and install the client on its default folder.
You can take further guidance from this website.
Hope this will help you.
