An internal error occurred SmAudio control in iPhone
A recent iPhone app released by Google shows the following error message upon startup
SpeedchExec pro Transcribe
An internal error occurred (SmAudio control).
How do I fix this?
How do I fix this?
This is not a type of error from the iPhone. It is from the windows application side. The error seems to be pointing at the smaudio control. There might be a chance that the application that you download which was released by Google is corrupted and you need to download it again.
If you are sure that it is downloaded correctly then reinstall it. Before reinstallation make sure that you have the latest audio drivers installed in your computer. SmAudio Control has something to do with your computer and not the iPhone. So you should better look for searching its remedy.
Go to the motherboard manufacturer's site and specify the motherboard model. Select the respective drivers and download them.
That’s right. That is not a typical iPhone error or a mobile phone error. Whether you are installing SpeechExec Pro Transcribe or SpeechExec Pro Dictate, make sure your computer meets the requirements. If you are installing SpeechExec 8.6, make sure you have a supported operating system and machine. SpeechExec 8.6 supports Windows 7 and Windows 8.x (Professional or Enterprise edition) both 32-bit and 64-bit.
Microsoft Windows 10 is not officially supported in this version. In case your edition of Microsoft Windows doesn’t include Windows Media Player like the “N” and “KN” versions, you need to install Windows Media Player manually prior to installing SpeechExec Pro Transcribe. The application also requires Microsoft .NET Framework 4.0. If you don’t have it, it will be installed automatically as you install SpeechExec Pro Transcribe.
SpeechExec Pro Transcribe requires 1 GHz or faster Intel Dual Core or equivalent AMD processor, 1 GB RAM for 32-bit and 2 GB RAM for 64-bit, USB port, 1024 x 768 screen resolution, 1 GB hard drive space for 32-bit and 2 GB hard drive space for 64-bit, and sound card.
