Internal error in the software.
This message is appearing again and again. Executing an Internal error message, “software exception c000000 (memory access violation).
Does anyone can knows how to fix this problem?
Need your help guys.
Internal error,
Answered By 0 points N/A #144438
This Internal Error is a common windows access violation error. This 0xC0000005 error is an illegal memory access violation. This is caused by incorrect or corrupt driver, you have a faulty RAM, poor updated software and installation of malware/adware installations.
This usually happens when you are performing these tasks. You need to check a website/support department  about this error. This will occur when you use Internet Explorer 6.0 to open an HTML document or a Web page that contains SPAN tags.
If a SPAN tag is not closed correctly by using the </SPAN> tag, an access violation may occur (You need to upgrade to IE9). Other software/application are incompatible with data execution prevention.
Applications which are dynamic code generation (such as Just-In-Time code generation) and that do not explicitly mark generated code with Execute permission might have compatibility issues with data execution prevention.(I guess you are familiar with this).
Answered By 590495 points N/A #313801
There are many reasons why a “memory access violation” is triggered by an application and one is permission. If that error keeps appearing on your machine as you use your computer, check the name of the application that causes the error and verify if that application runs or starts with Windows. If that program starts with Windows, try to disable it to isolate the problem.
Download the free version of CCleaner and install it. Once installed, start CCleaner then go to “Tools” on the left pane and select “Startup” on the right. In “Windows” tab, scroll down and select the application that causes the error then click “Disable”. Restart your computer then see if it works. If the error stops appearing, uninstall and reinstall that application.
Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select the faulty program among the applications and click “Uninstall”. Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then restart the computer. After booting, install the program back then see if it works.
