andra2091
10 points
Posted on - 09/26/2011
I was trying to use the Norton Ghost 2003 to clone my hard disk and it worked. But when I restart the computer and enter the "ghost" start up, my PC error and do the restart again and again and again. And when I tried to go back to the Windows, there was a pop-up error message says "Internal stack overflow system halted". So what should I do? Can you help me?
smith84
Stack overflow system halted error occurs because of too low stack space specified in config.sys file.
1)Â Â Â Â Â Unhide protected operating system files using folder option. Follow the steps below in image.
2)Â Â Â Â Â Go to C: and open config.sys in notepad.
3)Â Â Â Â Â Edit the config.sys and make sure that line STACKS are at least set to 12,256. For instance, the line should read like:
STACKS=12,256
Restart your Pc and check whether it is working fine or not, I hope it will be working fine. J
