tomusher
Posted on - 02/15/2012
Hello
With the help of Domino Lotus Notes and several SAP's (R/3, SEM, BW) I have finished to set MTA. I am able to send mails from SAP to Lotus Notes.
Is the internet address compulsory (in User maintenance (SU01), Address, Communication setup)?
The Comm. type looks not to be essential (I have tried blank, Remote Mail and Internet Mail (SMTP))? A CPIC "mailadm" user is mentioned in files regarding MTA. Is it compulsory?
I get the impression that it's not needed.
Am I correct or wrong?
Need your help. Thanks a lot.
Hi
This error appears because of your window which is not working properly. There are two options for that. One is if this application is working fine then that good if this application is not working fine then either run this application as RUN AS A ADMINISTRATOR. The second option is only you need to install the window again. This is the problem when windows.JAVA script or something might not work properly and if you installed this application again and still it does not working properly then I suggest you to install your window again. Hope this solution will satisfy you.
The problem seems that you need to change the Firefox and reinstall it with the original package of Firefox 7.0 or anyone latest you want. These problems are occurred due to up gradation because when you upgrade the software something might missing .
