kristan lai
30 points
Posted on - 04/04/2012
I am having trouble with internet browser. It is not accessing certain websites for which I am in serious predicament. I need to know what is causing this problem and how to solve it. I need help with this problem as quickly as possible.
Kindly someone knowledgeable enough help me with it.
Kristan Lai
Internet browser restricting accessibility to
Are you using Google Chrome, Mozilla Firefox or Internet Explorer? Sometimes I get this problem with trying to access some sites with my Chrome but there are many causes as to why we can’t browse some websites. Here are a few things that you can check:
Your browser might be attempting to connect thru a proxy server. Try connecting with your proxy server off
You might have incorrect browser settings. To change connection settings, Go to Start> Control Panel > Network and Internet and then Internet Options.Click on Connections,check your settings and make the necessary setting adjustments
If you’re using a router, your router might be attempting to proxy DNS requests. Refer to your router manual for instructions on disabling DNS proxying
Parental Controls, Family Safety or a firewall could be blocking access to certain websites. Check on this one and make the necessary adjustments
There can be several reasons for this problem. Same problem and overcome technique discuss below-
The site could be temporarily unavailable or too busy. Try again later.
Make sure that if your network is protected by a firewall.
If unable to load a page. Check your network setting.
If any security setting trouble. Then you should check for virus.
You should check your browser history and try after deleting history.
Malware could be block your browser.
