Windows Vista Internet Connection or Virus Issue
My laptop restarted, when it came back the looping Windows Advanced Booting Options appears. Upon choosing from its options, all of it had the same effect and it does not resolve my problem. I change the value of my SATA to IDE to AHCI something. Luckily, I was able to open my windows but it was really, really slow and everything there is not working. My firewall cannot be adjusted to on or off. And there is no options for disabling my anti virus if it's the one blocking on my system.
My internet has an error too. It is connected but limited or no connectivity. Clicking the start button will took a few minutes before it drop up to show the menu. Opening control panel or any other applications had the same effects. Is this another kind of virus? I opened my Device Manager, I saw a yellow with exclamation point beside the Network Adapters. I troubleshoot the problem of my internet connection and it says, my driver has to be updated. How can I search for an updated version I lost my connection at first. I am using ESET Smart Security 4 as my anti virus, why is it interfering with my internet connection? I am running Windows 7 Ultimate x64. Please help me.
