Internet connection problem with LG G2 Smartphone
Hi there,
I have a data plan with my network carrier and my LG G2 Smartphone is giving me problems, only Facebook and the default browser can access  internet connection, Opera mini and Whatsapp are giving a connection timeout error message, what could be the problem? How can I correct this?
Answered By 0 points N/A #199715
Try turning Airplane mode on and then off again. The quickest way to do this is probably to hold down the Power key until you see the Turn on Airplane mode option, tap it and then tap OK. You can also get to it via Apps > Settings > Tethering & networks > Airplane mode.
Or
This issue should be dealt with by a software update which should come over-the-air (OTA) when you are connected to Wi-Fi. You can always check that you’re up to date by tapping Menu > All settings > General > about phone > Software update > Update now.
