Jack Amber
Posted on - 03/21/2012
I am using D-Link switch that connects my local network to my ISP with ZTE MF612 Wireless Router. But I was unable to get a internet connection when using the switch even though I have a firm connection. How can I be able to fix this?
Internet connection using ZTE router and a switch
There may be a problem with your router. Sometimes Router hang & does not work properly. But it shows internet connectivity available. So you should check your router first. If you face same problem after that, You should configure your D-link switch & adapter setting of your connected PCs.
You need to allocate specific IP rather than the setting “Obtain IP automatically”. Go to “Network & sharing center” & change adapter setting. Put the setting like my uploaded picture. You need to put value in the “IP address” tab like that, if you put 172.16.17.1 in a pc than you need to put 172.16.17.2 in second PC. Hope it will solve your problem
