Internet download manager asking registration information after regis+B13987tration
My current version of Internet download manager is asking registration information even after registration. This is causing trouble in while downloading. It stops downloading after half the download is complete. So I am unable to download some necessary files lately. Please help me solve this problem as quickly as possible.
Wendell Montego
Answered By 10 points N/A #116611
Wendell,
If you got your internet download manager off the internet, maybe you downloaded the trial version. You need to go back to that site, or go to their official website, http://www.internetdownloadmanager.com/ and download the full version. Then now you can apply the registration code that you bought with it. You have to ensure that you get the correct version of software, the one that relates to your registration information, otherwise it might not work.
You can also uninstall it, and remove all its components, then reinstall it and apply the registration information that you acquired. In the meantime, if the file you want is urgently needed, when pressing the download button, make sure you hold on to the alt key so that it can manually download the file using your browser’s downloader.
Hope this helps.
