Internet download manager (IDM) problem with YouTube
I use internet download manager (IDM) to download videos from YouTube and other websites but recently there is a problem with videos in YouTube that IDM instead of downloading all video it downloads part of the video. If video is 10MB it downloads 1.2MB.
So please anyone tell me what is the problem and how to fix.
Best Answer by technicalgeek
Answered By 0 points N/A #91730
Yes this problem are mostly occur for the new users of IDM. you can solve your problem by changing the setting of IDM to your default setting. There are some setting which is changed form default and that why the IDM is downloading part of the video instead of full video.
To see these setting go to main menu in IDM and then select the option from the help and make the IDM to default setting.
If still your problem is not solve then contact to the IDM support center for the problem.
Thanks and thanks for asking in techyv.com.
Answered By 0 points N/A #91731
It may happen when some video accelerator has installed to speed up video in web players. Make sure that you use the latest version of IDM. Even latest version IDM may cause problem with such kind of accelerator.  When you use IDM its give you maximum speed of download so no need to install such kind of program.
It may help.
So my request does not install any kind of video accelerator and uninstall all types of video accelerators from your computer.
I hope it will work.
You can download the full video from internet.
