Internet download manager is not working on firefox 4
Asked By 140 points N/A Posted on -
Hi people!
I've tried a lot but could not find the problem. Can anybody tell me why my internet download manager is not working with my Firefox 4? I''ve also enabled advance browser integration in internet download manager but Firefox could not install IDM plug-ins. Help me to get rid of that.
Best Answer by victorr
Answered By 0 points N/A #85852
You must update you internet download manager.  You are using IDM 5xx series.  That does not work on Firefox 4.  Install a new version and that is IDM 6.05 build 8. It is the latest version of IDM.  install it and Firefox plug-ins will automatically install. Moreover, you first have to uninstall your previous version completely, other wise new version will not work properly.
Answered By 140 points N/A #85854
Yes, now it's working.
Thanks victorr.
Answered By 0 points N/A #85857
No problem. Whenever you install new versions of different software, you must need also new plug-ins. So, this is how it works. Stay up to date with software, then definitely, there will not be any problem.
Answered By 140 points N/A #85859
Yes, I just thought, that it is a problem with my Firefox. Thanks for your solution. I must have to think about IDM as well.
