Internet Download Manager Re Setup
How Can I Re Setup Internet Download Manager In To My Computer Which Was Expired 30 Days Trial Version?
Hi Sershadahmed,
The best advice which some body can provide with sincerity is that you purchase a licensed version of IDM, when the Trial Version has expired.
However, if still want to continue this trial version again, and Re-Install it, then perform these steps:
Un-Install the Internet download Manager, using its own uninstaller. Delete the remaining ashes of IDM, the left over files and folders.
Scrap the information stored in the registry, by doing the following steps:
1. Open the registry editor by, clicking on start- Run- and typing “REGEDIT” (without quotations).
2. On the open column, click on my computer and press Ctrl+F.
3. On the popup type “ IDM”, and click on find next button.
4. On the results, at the right of the column, simply delete the registry found, and then again press F3. Keep on repeating these steps, till the search informs you no more registries found.
5. Close the registry editor, and re start your system.
Now, try to install the trial version of IDM again. It should install without any issues.
PT
There is no other way but to purchase the software from their official website. If you have downloaded the trial version and it already expired, there should be a window wherein it will tell you to purchase the software to continue using it. Just click on the Buy Now link and then enter all the information needed. But if you don't want to purchase it, just simply uninstall the software and re-install it back.
Thompson Locker
