I am having some problems regarding uninstallation of internet download manager. I have uninstalled internet download manager. After restarting the PC the internet download manager icon still appears and it shows 9 files missing. Please help me solve this problem.
Robbie Lucas
Internet download manager still appears after uninstalling
Robbie, It is a common issue with most users. The software doesn’t get removed completely. For that, You need to go to Control Panel, then go inside Add/remove programs. In the list there, find the program Internet download manager and double click to un-install it completely from the system. It will solve your problem.
If still the problem is not solved, then you can re-install the software at the same location. Now you can try uninstalling it again. It will be successful this time because now you have the complete software without any files missing and you can easily uninstall it. You will have no problem now.
