Internet download manger Integration with firefox
I am currently using internet Download Manager 6.09 build 3. I have due dated my Firefox browser to version 11.0. Now IDM is not integrating with Firefox. So how can i do it manually?
Hey Abel!
I am a user of Mozilla Firefox and I uses Internet Download Manager to download files. Both have a great combination. I really enjoy their services.
The solution to your problem is very simple. You just have to follow these steps to solve your problem.
1. First of all open Internet Download Manager.
2. On the upper toolbar, click on "Downloads" tab and select options.
3. Internet Download Manager Configuration box will open. Click on General Tab.
4. Here you can see a list of all browsers. Check the box against Mozilla Firefox and click OK.
If that box is already checked and your browser is not working with Internet Download Manager then follow these steps.
1. Open Mozilla Firefox browser and click on the Tools tab and select "Add-ons".
2. Here you can see the list of all Add-ons that are working with Mozilla Firefox.
3. Find the IDM add-on and remove it (As it is the older version).
4. Now you need to install the new Add-on for the IDM.
Click on the following link that will install the latest Add-on for IDM
http://www.internetdownloadmanager.com/idmmzcc/idmmzcc.xpi
Install the Add-on and restart the browser.
Now your IDM will work with Mozilla Firefox.
Thanks
Internet Download Manager 6.09 build 3 does very well integrate with Mozilla Firefox 11.0. Let me try your problem to solution.
