Internet Explorer 10 Keeps Crashing Along With iTunes?
Hi TechyV buddies!
I have encountered problems using Internet Explorer 10 on Windows 8. Every time I open Internet Explorer 10 it always end up crashing whenever I try to download. Loading large programs like iTunes also crashes instantly. And now I can’t even open Internet Explorer 10.
I have tried to find out if any viruses are causing it so I have run my antivirus but it end up finding nothing. Can you help me configure the issue of my computer?
Thank you!
Best Answer by Fosso pradha
Answered By 5 points N/A #149145
Try the following workarounds to fix your problem:
1. Press Windows key + R or the Run window.
2. Type inetcpl.cpl and then press the enter key to launch the Internet Properties window.
3. Select Advanced Tab.
4. Untick the check box beside the Enable third-party browser extensions under the Browsing group.
5. Click Apply and then OK.
6. Restart your computer.
Answered By 0 points N/A #149146
Dear User,
I would suggest you to reset your internet explorer settings. You do not have to open it to do it. Just follow these steps.
Go to control panel click on network and internet.
And then open Internet Options.
This menu helps you to manage the browser and add ons.
Internet Options Accessibility
Click the advanced tab and press the reset button.
If this doesn’t fix your problem, try reinstalling iTunes or reinstalling your OS.
Thank you.
