tsaima
Posted on - 10/15/2011
Whenever I try, I get error messages such as:
The instruction at "0x100073f3" referenced memory at "0x00630052". The memory could not be "read".
The memory addresses are different every time. I have tried uninstalling IE and reinstalling it to no avail.
I have been using Firefox, but it also has begun behaving funkily – taking FOR-freakin-EVER to load, etc.
So I'd like to get IE working again.
Internet explorer 8 won’t start
It's working right now. Just I check my all hard disk after restart my pc it's working fine. If your window file is corrupted You can reinstall windows.
What setup are you using this on? A XP or Vista OS?
Did you get the installer from the IE page or did it install from Windows update?
If you are facing this problem then it is fault in your system the browser you mentioned is some what latest browser and it is supported in latest pc so improve you system spex !
And if you have latest pc and you are facing this problem then your system is badly effected by the virus !
So please scan your system from virus  your problem will be solved !
Thanks !
