Internet Explorer 9 – constant Tab Settings reset
Hi there,
I keep losing my tab settings on IE9.  When I open up the browser it goes to a blank page even though I set it to go to cnet.com.
I close the browser after adjusting the settings, but then it goes to a blank page again!
What do I do to fix this?
Answered By 0 points N/A #147819
Hi Kent,
You mean you set your home page to cnet.com and when you open a new tab which is supposed to be at cnet.com, goes blank instead?
Remember that when you open a new tab, it will always depend on what is the first homepage that you have selected.
Here's how:
1. Make sure that all windows applications, programs, ie windows open are closed.
2. On your desktop, click on Control Panel [Please refer to the image below]
3. Then in Control Panel > Select Network and Internet > Internet Options
4. Under General> Click Settings to the right of Tabs [Please refer to the image below]
5. A new dialogue box for Tabbed Browsing Settings will pop up.
Here are the two things you may do : [Please refer to the image below]
[Either put a check mark on the box for "Open only the first home page…" or select your home page on the drop down when a new tab is open:]
Re-open internet explorer and you should be able to see cnet.com as the page instead of a blank page.
Hope this helps. Please don't hesitate to post any questions in addition tois thread.
