Moose Lodge
20 points
Posted on - 03/27/2012
I have Internet Explorer 9 installed in my computer and I am using Windows 7. Now, Internet Explorer is troubling to browse.
That is why I want to re-install Internet Explorer 9 in my system. But problem is when I try to install it,
I get the following message.
So how can I re-install Internet Explorer 9 in my system?
Error:
Windows Internet Explorer 9
Internet Explorer did not finish installing
Setup can't continue because a more recent version of Internet Explorer is installed on your computer.
Internet Explorer 9 re installation
Hey Moose Lodge!
This error occurs when the software you trying to install is older than the version of installed software. In your case windows 7 has Internet Explorer 9 by default. The Internet Explorer you are trying to install is older than the Internet Explorer 9. That is the reason the windows is not allowing you to install the older version of Internet Explorer.
First of all you have to make sure that the version of Internet Explorer you have is 9. Download the latest Version from the internet. Then you have to uninstall the previous installed Internet Explorer. After that run the setup of new Internet Explorer. You will not face this error message anymore.
Thanks
