Internet Explorer 9 won’t install on 32-bit Dell Machine
Although I was able to install internet explorer 9 on a 64-bit machine, I am experiencing problems while trying to install it on a 32-bit Dell machine. Every attempt to install it returns an error message. This message directs me to a web page that offers four possible solutions to the installation problem of internet Explorer 9. Application of the solutions has however not enabled the installation of the Explorer 9. Browsing the internet in search of a solution to the problem with the explorer 9 has yielded no solution. I am of the opinion that the problem I am encountering while installing explorer 9 is a result of the “trusted installer” common with Dell products.
Do you know the solution to my problem?
Thank you.
