Hi everybody,
This is the most common error message which I believe every internet user would have come across. Message displays as ' Internet Explorer cannot display the webpage' and then operation aborted.
I've also searched various blog sites, but couldn’t find any specific solution of this problem. Error message is general in nature and doesn't highlight the targeted error.
Does anyone know what could be the possible trouble-shooting steps when the user encounters such type of error?
Thank you
Lilly
Windows Internet Explorer
This window is busy.
Closing this window might cause some problems.
Do you want to close it anyway?
katsaman
Internet Explorer cannot display page
Hi Lillly,
Here are some troubleshooting steps you can try to resolve this Internet Explorer issue.
First:
Clear your browser's cache and cookie or your browsing history. Follow the steps below to clear your history, temporary files and form data.
a. Click "Internet Options" on the Tools Menu.
b. On the General Tab under the Browsing History category, click the "Delete" button.
c. Select the check box right next to the ff: Temporary Internet Files, Cookies, History and Form Data.
Second:
Use the Internet Explorer Safe mode or the "No Add-ons" mode. To do this Click Start > All Programs > Accessories > System Tools > Internet Explorer (No Add-ons).
Note Internet Explorer (No Add-ons) mode is only available for Internet Explorer 7 and Internet Explorer 8.
If it works at this point, follow these steps so we can isolate the browser add on that is causing the problem.
a. Click Tools, and then click Internet Options.
b. Click the Programs tab, and then click Manage add-ons.
c. Click an add-on in the Name list, and then click Disable.
d. Repeat step 3 until you identify the add-on that is causing the issue.
I hope this resolves your problem. Here is a link for more information and some solutions you can try if my solution didn't solve this issue.
https://support.microsoft.com/en-us/help/956196/-internet-explorer-cannot-display-the-webpage-error
Kat Saman
